im on a budget build so no 1k+ turbos for me. im a diesel tech so i think im up to the task of rebuilding the ct26 in stock form to get me through the winter...i read a good writeup and im concerned about the machining and balancing part of it all. i was really just hoping i could press new bushings and seals in then after the shaft marks are lined up i could call it a day.
im wanting to hit 400whp...eventually. i have hks mhg and arp's already on a fairly fresh rebuild so i think its up to the task. but with the turbo being so loose im afraid its about to start wearing into the housing or eating up seals...that may change with oil pressure, but if you can see the shaft move i think its bad enough to replace/rebuild.
so my question, is it logical to get the 75-100 rebuild kit, get the machining done and then balancing...how much power is the stock ct good for? im sure 400 is a pipe dream for that turbo but maybe something like 320-350?
basically what turbo's are everyone going with to meet that 400+ goal and how much is it going to cost me to swap it in, which are easier and what do i need to stay away from? is a different turbo going to do anything negative for just daily cruising or will it just destroy my fuel mileage?
thanks in advance
thanks in advance
