Turbo pressure sensor i can remove?
89Turbo
804
Portland
I read somewhere(cant find it now) that there is a turbo pressure sensor somewhere on the drivers side engine bay that you can remove if you have an aftermarket boost gauge, which one is it and can i really with no ill effects? basically just continuing to clean my engine bay up.
robeats91t
237lbs. of Ballast
Jun 4, 2005
210
Tampa, FL
I've had mine out for awhile...no ill effects. Pulled it out when I added my GReddy electronic boost gauge.
I recently got a code 31 or 34 (I can't remember, it's been a few weeks) but I think that was fuel cut--I got the code after removing my FCD.
koulee
497
Its got a label on it, its in the general vicinity of the ignitor I think. All it does is send the signal to the boost gauge, so yes, you can remove it if you want to.
supra90turbo
shaeff is FTMFW!
MA, 01440
That would be the only reason to do it.
It's fine. All it does is control the gauge. There will be no ill effects from removing it, other than a dead stock boost gauge.
89Turbo
804
Portland
if im running 8+ lbs i dont need that anyways, i have an aftermarket Autometer gauge which is the only one i look at so im taking it out just to clean the engine bay, i store all these parts i dont just throw them away so if i ever did need it i would just throw it back on.
robeats91t
237lbs. of Ballast
Jun 4, 2005
210
Tampa, FL
Heh, that's what I thought...but the stock boost gauge pegs 8psi when you take the sensor out...it's kinda annoying, at least to me. I ended up getting a voltmeter to put in its place, which is an easy swap.
It's kinda hard to get used to looking somewhere new for the boost gauge, especially after 4+ years of looking in the stock location.
89Turbo
804
Portland
same with that huge vacuum acuator thing that was attached to the cruise control bracket right? i can get rid of that, there are no more lines that need to be connected to it after no cruise control, pressure sensor are gone right?
