turbo overheating?
bombinuass
431
Dahlonega, GA
well guys... when i drive my car hard my turbo glows red.... things i have checked/ know about... i know my timing is off 2 degrees.. cat not clogged. is timing off 2 degrees enough to make it glow? i got to pull cps and put it in right. but havent done it yet. car preforms ok with it off 2 degrees so it isnt my main priority. plus i only have sunday nites off and thats it. but now i have to drive my car WITHOUT boosting because my turbo glows:( so i gotta drive like a granny lol. any other causes yall can think of that might cause this? Thanks.
mk3tattoos
1,104
Bremerton, Wa
the timing will efect EGT's so mabey you should set it back to what the tsrm says and go from there or fix the cps. do you have your heat shield on? and one more thing, try taking a video of it glowing so we can see it. might help the guys out.
and always post a list of mods that is done to the car to help out as well.
bombinuass
431
Dahlonega, GA
well thanks. i knew that timing being off alot would cause the whole exhaust to glow. but i never figured just 2 degrees. but i guess this is my next project. only have very little time:(
Pull #1 plug, grab an old chopstick and sit it on the piston then turn the crank with a ratchet and wait for the choptick to stop them compare the mark on the damper to the one on the timing case.
89supra7mgte
797
colorado
so the cps is set 2 degrees off, or 2 teeth off? I would think if you are off you could be able to adjust 2*, but if you are off 2 teeth might have some trouble bringing that back in.
Positive CATS are not plugged? there are 2 and the one on the downpipe is a bitch to verify, with the bends.
bombinuass
431
Dahlonega, GA
well i can only get the timing to set to 8. so im assuming its just a tooth off. anf as far as the cats go... i can blow leaves bout 10 foot behind my car. so i wouldnt think so but correct me if im wrong.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,242
Atlanta
Well, the exhaust is till going to come out the tailpipe, it's just that it has to work that much harder(and heat way up in the process) to do it.
