turbo oil return line question
grimreaper
2,180
Dallas
for the guys that have removed the return line before, can it be done with the turbo on the car?
seems the solid return from the turbo to the end of the oem connector at the block is joined with a small section of hose and hose clamps. I found one clamp dangling and more oil to add to my clean up efforts. Unfortunately the hose/connector is a bit to big I.D. and the pipe coming off the turbo is not sealing 100%
option
A) new braided ss line from driftmotion
B) put a smaller connector between the two pipes,
i hate to remove more then i need to to get to the bolts on the block and what not, any tips?
MKIIINA
Destroyer of Turbos
Plano, TX
i think i did it once with my jt61 at one time but it was alot more trouble than worth. taking it off the block is easy but off the turbo is not fun. pull the turbo
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
yea.... its definetely worth it to take off the turbo
with the turbo on.... its a serious PITA just to take off those 2 little bolts, much less changing the hose
good luck
-pete
grimreaper
2,180
Dallas
ok i think ill just pull it off, good time to double check the manifold bolts too,
how are you guys getting a tq wrench on the turbo to manifold bolts?
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
its a lot easier when the motor is out of the car.... actually, im not even sure if its possible when the motor is in the car.
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,585
Great Lakes State
You can do all of that with the motor inside the car, it isn't much of a pain really after you've done it this many times. You can also torque the exhaust manifold bolts, it is possible because I do it.
grimreaper
2,180
Dallas
turbo removal took me an hour tops, first time as well.
Do you tq studs down any before installing the manifolds and nuts? or just finger tight?
