Turbo Jet Engine.
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
interesting shit...
http://www.junkyardjet.com/
Mk3runner
2,033
Nor Cal
I built one before at school to show the ricers how to blow up a old turbo with style. it would have lasted far longer but I was too lazy to rig a oil system to it. those little mitsu 14g sounds wild..
turbo outlet goes into the exhaust side of the turbo compressed with fuel and is burned... (notice the loop and how hot it gets?)
turbo is to a jet engine what a wankle supercharger is to a rotary...
Dirgle
Conjurer of Boost
Pauma Valley, CA
Kind of interesting how they hooked up a second pump to the exhaust manifold for the afterburn effect.
Pretty cool idea but I bet longevity and efficiency go right out the window. Non the less, plus one for effort and ingenuity.
tte
Breaking In - in progress
Northern California
Could modify a stock turbo, remove the center section and make a combustion chamber with fuel injectors to fit in there....After the turbine extend the end with a nozzle and have more injec tors to ignite the hot gases.
Damn....Wouldnt be very expensive to play with.
Cheers,
Roy
wouldn't work quite the same way, as the compressor isn't straight through...
basicly a jet engine is a linear compressor while you have to loop a turbo to do the same thing...
wonder how long the exhaust turbine lasts...
tte
Northern California
Oh yeah...true...I forgot the jet engine uses axial compressors unlike the automotive radial type compressors.
Cheers,
Roy
yankiwi
221
DFW
Early jet engines were centrifugal compressors very much like a turbocharger...
Not too different than the setup here. Just had a longer shaft between the compressor and turbine, the combustion chambers where located around the shaft..The axial flow become popular quickly cause it has a smaller frontal surface area=less drag...
OK, thats as geeky as I get LOL........
