Ok every body shooosh for a second and let me edumakate you:
There are 4 ways a diesel ignites its fuel:
-Preheat the air with coils
-Preheat the fuel before injection to the point of combustion
-Heat the combustion chamber (glow plug) untill the chamber is hot enough to self combust
-Compress the incomming fuel to the point of self ignition
99.9% of all diesels (haven't seen one yet, but Im sure there is at least one out there) do NOT HAVE A THROTTLE BODY. The throttle is controlled on how much fuel is injected into the combustion chamber. The turbo itself never sees a vacuum on the compressor side because of this.
Turbo diesel engines do not have BOVS.
Now as for diesel combustion:
1.)Preheated coils. Most commonly found on Cummins applications. There are giant heater coils like the ones you find in a hair dryer, inside the intake plennum. They heat the air so that the fuel can burn inside the combustion chamber. This combustion is ignited by a very sharp dome on the top of the piston. It litterally self detonates.
2.)Preheated fuel. This practice is still in use, but mostly only used in cold climates. Diesel has to be hot or warm to self combust. Again its all about a controlled self detonation.
3.)Heating the combustion chamber. This is the typical glow plug. The glow plug only runs untill the combustion chamber or piston is hot enough to continue to self ignight the incomming mixture.
4.)Ignition by compression. We all know that you can't compress a liquid to a certain degree, and we all know that when you compress a liquid or gas the temp raises. Well this type of ignition is commonly found on the CAT engines around the world. It uses a computer aided cam advance/retard system that helps the pistons from being overly hydrolocked. Again, there is a very sharp machined point in the top of the piston. When the fuel is compressed (we're talking over 300:1 compression at times) it raises quickly in temp, and the top of the piston self detonates the mixture.
LAST:
There are two and four stroke diesels. Most on the road are 4 stroke because of the EPA. Want the biggest baddest diesel engine ever made for over the road trucks? V12 two stroke (might have been a v8 or 6) Detroit Diesel. It was a bad mammerjammer back in the day!
