turbo cylinderhead on n/a
Status
Not open for further replies.
supraman508
496
maryland
Hello turbo people,i have a N/A and i'm going to put a turbo cylinderhead on my N/A block.i talked about this on the N/A side but want to hear some of you gutys that have turbo supra and want to know will i notice anything different when driving.I do know that the N/A's do have a higher compression.
shaeff
Kurt is FTMFW x2!!!!
11
Around
You already got the only right answer.
http://www.supramania.com/forums/showthread.php?t=95757
And compression, stock for stock, has nothing to do with the head. It's due to the piston design. The only difference between the N/A and turbo heads is the intake cam. Other than that, you will notice no difference, if you're even keen enough to notice the difference with the cam swapped.
Don't doublepost again. Thread closed.
Status
