turbo clutch n flywheel in a N/A ?????
MKIIIChucky
101
south jerzy
I just got a clutch like 8 months , its been starting to where out sooo ive been thinkin on gettin a new clutch , i saw i thing where they have clutch n flywheel combo for like $650.00 , i just wanted to know if i was able to use a turbo clutch n flywheel on a N/A ??? i think it would be a little better for when i do my N/A-T swap !!!!!!! hit me back , let me know whats good !!!!!
Jeff Lange
Administrator
4,927
Sunnyvale, CA
jefflange.ca
The flywheel/clutch has to match the transmission. You could put in a turbo clutch/flywheel if you also put in a turbo transmission (R154), and then you'd need the other stuff associated with that (driveshaft, etc).
With the stock N/A transmission (W58), you cannot use the turbo flywheel or clutch setup.
