Hi guys i have a friend whos just had his 7mgte ma70 turboA dynotuned, and the technique the tuner used puzzled me a little.He first set the timing at 15 degrees(stock turbo A cams) then proceeded to tune the map ecu at 11 afr across the board and wouldnt tune the car over 14psi because he said the timing couldnt be adjusted any more....
I wasnt there when the car was tuned so im a little puzzled as to the technique used, I realise i havent given you guys much info to go with and ill add to this once i see the dyno sheet myself, but is this a common way to tune supras?
I always believed in setting the timing at 10-11 degrees and tuning from there..The tuner claims if the timing isnt set at 15degrees it kills the bottom end, but in my experience all that does is kill the top end as you cant tune any more for fear of detonation.?
Please help me sort out this puzzle, Its buggin the crap out of me and the company that tuned his car is very well known and respected.
tuner pulled 344rwhp at 14 psi(679nm torque).
(car engine specs)
1.2mmhks h/gasket
550 rc injectors
hks afpr
550whinebro
map ecu
60-1 turbo
p/p head
150psi across all 6 cyl
spearco intercooler
cooleze pipes
hks bov
(car engine specs)
1.2mmhks h/gasket
550 rc injectors
hks afpr
550whinebro
map ecu
60-1 turbo
p/p head
spearco intercooler
cooleze pipes
hks bov
