Well if you can weld or know someone or a shop that can, and if you are pretty set on it. You could always get one of the ss autochrome or ebay ones and change the flange over to a ct-26 one and run an external gate. That is what I was going to do because I wanted to see what I could do with a stock ct-26 but I just purchased a greddy 20g bolt-on that I could not pass up.
Also I remember seeing in dsmtuners a turbo dyno comparision thread where a shop was comparing turbo's to show people what the diferent turbo's where capable of. In one for the evoIII16g they compared a SBR cast mani to a SBR tubular one. Below is the post I am talking about. IMO if the price is right I think that a tubular manifold will be worth it even for a ct-26.
Quote:
Originally Posted by Slowboy
We had only linited time today to get the test done, we had a few dyno appointments. We did manage to spend some time with the MHI Evo III turbo however, notice on the 15 PSI graph the boost crept from 15 to 20 psi.... the opposite problem we have been having! This was an unported turbo with no 34 mm flapper to help control boost creep. It was only an issue when we tried to run less than 20 psi however.
15 PSI: 290 ft/lbs 344 WHP (crept to 20 PSI)
20 PSI: 344 ft/lbs 344 WHP
25 PSI: 400 ft/lbs 375 WHP
30 PSI: 436 ft/lbs 397 WHP (fell to 23 PSI at redline)
We can easily make 400 WHP if we wanted to run more timing, or if we were on our old 2.3l motor we liked to beat on back in the day! We will have this turbo back on once we go external as well.
http://www.slowboyracing.com/downloads/dyno graphs/E16G 15-20-25-30psi.JPG
http://www.slowboyracing.com/downloads/dyno graphs/E16G Boost Graph.JPG
Mike Huml
So, lately we have seen a lot of post on Tuners and other forums about tubular manifolds, so we decided to do a little testing of our own! It is a well accepted theory that a properly designed tubular exhaust manifold will pick up torque, and possibly make a few more WHP along the way.
So, we decided to install the SBR tubular manifold, and give it the SBR port job that this turbo deserved in the beginning.
Here is the note that was in my email from Nathan, (our tuner) so you can easily understand the graphs I am about to post:
"The third graph posted is a screen capture from the Haltech datalogger. It shows MAP pressure vs. intake temp. Much to our suprise, even at this boost pressure, the 16G didn't turn into a hairdryer. As you can see at the beginning of the run IAT is at a cool 20*C, about 68*F. As boost comes on, IAT rises to a peak of 27*, or 80.6*F. This is VERY good for an IAT, especially for a small turbo. Its not uncommon to see 140* temps on big boost passes on a small intercooler.
The IAT sensor is positioned right infront of the throttle body in the TB elbow.
Unfortunetly, we dont have an IAT before the IC for a temperature differential, but the hot side endtank is blazing after each pass, almost burns you to touch it, however the outlet cold side stays right around 80*. Pretty efficient setup eh?
Nate
SBR"
http://www.slowboyracing.com/downloads/dyno graphs/Evo-III-16G/E316G Tubular.JPG
http://www.slowboyracing.com/downloads/dyno graphs/Evo-III-16G/E316G Tubular vs. Cast.JPG
http://www.slowboyracing.com/downloads/dyno graphs/Evo-III-16G/Air Temp vs MAP.jpg
Maybe we should start a new thread to discuss this? Who wants us to throw some nitrous on this little MHI and see what its made of.... hehe.... :rocks:
Mike Huml
