OK guys! Thanks for the numerous suggestions you seem to be leading me down the train of thought i was beginning to follow. However, as you mentioned the problem with the thermostat, it is new. I had replaced it recently. BUT, because weird things fail, I tested it (pot of water test) and it worked fine. This lead me to believe that because my gauge wasn't working,and that it wasn't flowing. Apparently with the new three row radiator it takes a LONG time to warm up to operating temps. The thermostat finally opened on the car, and pressurized etc. But, gauge still doesn't work.
Also, I did ANOTHER inspection of my lines, and noticed that there was one tube (fat one next to the 3000 pipe that goes into round black thing on intake manifold... that i cant remember the name of...) it seems to be running MUCH better now. It seems to have been a conjunction of the bad ground to the igniter and a crack in the aforementioned pipe. I dont want to conclude that it is fixed, because after replacing that hose i havent had much time to continue messing with it. SO, I'll update you this weekend with anything further.
---------- Post added at 04:08 PM ---------- Previous post was at 03:55 PM ----------
sorry, i just remembered the name of what i was talking about in the above post, it was indeed the black hose running the the iscv valve. Upon removing it to check thoroughly, I noticed that there was a fairly large crack on both ends on the bottom so that they were not visible unless it was removed. This was replaced and I noticed improvement (AKA problem went away). However I am going to check it again this weekend when I get back from school and make sure that there is no additional problems.
SIDE NOTE::: Do i need to remove the entire dash to replace/repair my temperature gauge? Also does the blinker/headlight switch on the steerin column effect anything engine related? Because my switch is faulty, causing the dash lights, and headlights to flicker on and off iff wiggled or moved. I also noticed that when it flickered, the idle speed increased to about 1000 RPMS and gradually lowered itselg back down to the proper idling speed. There was an immediate and direct correlation to the idle speed and lights flickering. Maybe causing a weird short inside the switch?? I have another switch I am going to replace it with soon. SORRY FOR THE essays
