Hi all, so I got a CT26 with a 57Trim upgrade, now I'm in the process of installing it and have been running into many hurdles along the way. Most of them being problems with screws. On the 2 top screws connecting the turbo to the turbo elbow, the bolts holding them down are completely stripped. I had to use Craftsman specialty tool that will remove stripped nuts. Did so, so I'm definitely going to need new bolts. Aside from that I thought I was in the clear. Turns out that the bolt holding down the oil feed line is as well impossible to take off. I've used PB Blaster on all of the screws and bolts and even left them sitting overnight, still no results. As of right now I'm completely stuck on how to remove it. Anybody have any suggestions?
Thanks, Dimitris.
Thanks, Dimitris.
