Transmission won't shift!
lemmiewinks289
21
Texas
rayall01;1312615 said:
I've never loctited any flywheel, auto or clutch, and I've never had a problem. I gotta believe there's some other issue afoot here. Perchance some type of obstruction between the flywheel and crank, which would cause the flywheel to not seat properly. Check this thread: http://www.supramania.com/forums/showthread.php?t=93860
Um... it's the pressure plate bolts backing out. Not fly wheel. Either way, I read the thread you linked. It is possible that the threads are just fubar. Maybe crossthreaded. If so, then I'll have to re tap and die them... Or get a 1jz flywheel.....
I got it towed to a tranny shop. I'll pick it apart tomorrow and also do the rebuild myself in an environment which has the right tools.
rayall01
901
Westfield, ma
Sorry, missed that bit. I have a bad habit of skipping words when I read, as my mind is going too fast for my eyes.
