Transmission Question!
mjmendoza
95
San Jose
I have an 87 NA auto but my transmission seems to not shift out of second. I shifts perfectly fine sometimes but i dont get why it does it sometimes. If anyone had the same problem can you please help me thanks.
cuel
1,536
Baytown, Texas
^^ +1. If the fluid level is good (you check it with the trans. in park or neutral, engine running, and at operating temp., and with the parking brake ON), I'd lean toward a sticky solenoid, usually caused by contaminates from dirty fluid and a plugged up filter. Might be a good time for a trans. service...
iwannadie
981
gilbert, az
Check for trouble codes, takes a few seconds and can tell you everything you need to know. All you need is a bent up paper clip to check for codes too.
mjmendoza
95
San Jose
i might sound a little dumb but i never knew how you guys were finding out the codes. I know its something to do with a paper clip but i never knew how you guys got the numbers.
plaaya69
87T Supra
Nov 18, 2006
947
9
Lake County, IL
That could help but I would change it anyway. Also use Royal Purple automatic trans fluid. I used it in my 87 Turbo and it worked out well with No problems.
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
your best bet is to take it to a place, and have them do a full blown flush, running fluid through, while shifting through gears, etc. Then put quality a/t fluid in and a new filter.
plaaya69
87T Supra
Nov 18, 2006
947
9
Lake County, IL
^I would say anywhere from $60-$140 depending on where you take it. I know sometimes aamco has specials like they had a $79.95 trans fluid service awhile ago but also sometimes I see it also for $99.95 as well and maybe get some quotes from other places.
also like Burntz said get some good trans fluid because that is very important.
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
I've seen it for cheaper, but ull pay more if you want good fluid. If you wanna save ur tranny id suggest doin it.
