Transmission Plates/Starter R154 Swap
MichiganLC
64
Michigan
I'm doing an A340 to R154 swap. Will my A340 transmission plates work on the r154? How about the starter?
plaaya69
87T Supra
Nov 18, 2006
948
10
Lake County, IL
The starters are interchangeable through all year mk3 Supra's but the only difference is later model starters are threaded to help with the bolt installation but either style works.
What plates are you talking about?
MichiganLC
64
Michigan
I'm showing these transmission rear end plates to be the same on all transmission options.
11355-41010
Anyone know otherwise?
plaaya69
87T Supra
Nov 18, 2006
948
10
Lake County, IL
I know the larger upper plate (where the starter goes through and bolted to the rear block) is the same but I think the lower plate is the same as well. I am currently doing a auto to manual conversion and I have both plates and they look similar.
