I just bought my first Supra a few weeks ago, and almost have it running. The only snag I'm running into now is this:
Yesterday, I tried to start my car to discover that the engine wouldn't crank. After a bit of troubleshooting, I seems as though the neutral safety switch failed. I followed the steps in this tread to temporarily bypass the switch which are:
"find the circular clip on the intake side of the harness its one of the circular ones that used t be attached to your tranny..
it should have 3 wires almost looks like a smiley face...
I I
_
kinda like that..... jump the two that are I I and that will jump the switch..."
The wires were a black/blue wire, and a black/white wire. Once I jumped those together, the car started and ran as expected; except that it stays in first gear, and doesn't up shift into any other gears. I also noticed that my speedometer isn't working. I have no idea what's stopping the trasmissiion from up shifting, and I don't know where to start to look. Would you say that my problem is with the safety neutral switch, speedometer, or do you think my problem is elsewhere?
I I
_
