Tranny leak
madseacow
360
Buda, Tx
I've got oil comming out of the drain hole real bad, like to the point where my clutch sometimes slips. I've FIPG'd the oil pan and put in a new RMS some time ago but it still leaks... it leaked like this before I had installed the 7mgte so could something on the tranny side be leaking or something? what else could be letting oil in there? I hate to go through all the trouble of replacing the RMS and find out that's not it again.
8,897
Then get a new pan. If your oil is coming out of the drain plug. Don't over tighten the plug.
The surfaces for resealing the pan must be perfectly clean and flat, just like a MHG, take your time.
Oct 11, 2005
3,819
21
Thousand Oaks, CA
Confusing post. Are you talking about the drain hole in the bell housing, or the drain hole in the oil pan? If the bell housing, then sounds like a bad rear main seal.
