Tranny Flush.
Sl1dewaysSupra
Destroyer of FWD's
Mar 14, 2006
690
Colorado
So I am going to do a tranny flush in the very near future, I want to use Redline Manual trans. fluid. Will I have any issues because my tranny has 160k miles on it? Will switching to a synthetic fluid make any thing worse?
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
I use redline in mine. I'm running 170K on mine and haven't had an issue.... except for getting that evil fill plug out. Also, make sure you fill with the proper amount if you end up filling through the shifter hole, the W58 requires alot less than a R154.
Sl1dewaysSupra
Destroyer of FWD's
Mar 14, 2006
690
Colorado
^ Yeah, I was gonna pull the fill plug first. I figured that if I already had the shifter out to replace bushings I might as well change the fluid too. As for the amount of fluid TSRM FTMFW!!!
Ninja Edit: Check the cyngus site or the TSRM BorHor. I'll try to look it up quick like for you.
CRE
Oct 24, 2005
3,485
Denver, CO
UMM, you're CRE?
:yelrotflm
Well, I was actually going to rent that space out, and failing that give praise to Jeff Lange. But yeah, that works... "When you're good, you're CRE" Except that when said out loud it make me sound like some sort of snobbish cheese spread.
I'm running MT90
Sl1dewaysSupra
Destroyer of FWD's
Mar 14, 2006
690
Colorado
^ Yeah, it was weird typing it. Y-O-U-R-E C-R-E, the last two letters of each word threw me off. As for the viscosity I will just use what the TSRM recomends. Oh, almost forgot. It's K-R-A-F-T not C-R-E. LOL.
CRE
Oct 24, 2005
3,485
Denver, CO
Read the info on the redline oils, some have modifiers in them which I don't think are necessary. This has been gone over a few times and I think MT90's the one that's usually recommended.
Actually, looking at Redline's site, they recommend you use the 75w90 for diffs... they say it'll work in a tranny, but their other oils are recommended for better performance: http://www.redlineoil.com/products_gearlubricants.asp
And MT-90 IS a 75w90 weight BTW. http://www.redlineoil.com/products_gearlubricants.asp?productID=46&subCategoryID=17&categoryID=7
Sl1dewaysSupra
Destroyer of FWD's
Mar 14, 2006
690
Colorado
Mabey... I might do the tranny flush this weekend if the weather is dry, and if I get the bushings and source the Redline soon. Where did you obtain yours CRE?
