So I went to re-calibrate my tps sensor with the help of a friend and a nifty snap-on voltmeter. And after a while of trying to re-calibrate the sensor I plugged it in and went for a drive. In first gear I almost get to about 2000rpms then the engine cuts power, I dont mean it shuts off, it just gives me no fuel, almost goes into a limp mode. Then seconds later it accellerates again but only to 2000rpms then falls on its face. I am using a JDM throttle body and the sensor that is on it has a blue toyota/denso sticker and the inside is straight up and down. Now, the old throttle body that was on my car used a tps sensor than was horizontal, could it be the computer only recognizes the pre-89 throttle sensor? Im clueless because it runs fine without it plugged in.....Any ideas, thoughts,suggestions are welcomed! Thanks
