Is there any possible connection between running rich and the TPS needing adjustment? I am getting 21 and 51 for codes and am trying to figure out how to solve what's going on. I have put on a new TPS and am wondering if I need to adjust etc.
astkgse;1630129 said:K. I have adjusted the TPS and the timing. Both are plumb according to the TSRM. BTW be sure to adjust the TPS based on your engine. It seems there are many who have had problems adjusting the TPS. The two engines (7mgte & 7mge) have sensors that are opposites to one another. The terminals are inverted one from the other. I may be the only idiot out here who didn't realize that initially but at least you can learn from my mistake if you, too, are prone to be stupid.
The adjustment solved the code 51 but I am still getting a code 21. Anyone know reasons this would be the case and where I should begin looking?
astkgse;1630502 said:Yes, it is a GTE. Just checked that resistance and it reads 0.00. Will replace. Thanks for the info.
