Toyota Red Coolant = ?
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Aunt Jemima is best ;)
You absolutely must use Toyota coolant because other types of inhibitors are completely ineffective on the exotic metals used in Toyota engines. Super secret alloys found only in Japan you know. Same goes for the water in OEM coolant ;)
Grimsta
1,081
Santa Rosa, Ca.
Jet & Summet: I guess I didnt phrase it right, but I didnt mean to say ALL coolants are the same as well. Obviously there are differences of forumlations out there with well known Dex Cool being the best example. But what I was trying to get at was the mentality that you have to use the BRAND of Toyota "red" because its from Toyota instead of another BRAND that is the same formulation. Sort of like Zerex that has been brought up in here
Mo87NA
1987 7M-GE & 1991 7M-GTE
8
Upstate NY
Has anyone heard of the Toyota Pink? When I was searching for Toyota Red, I came across the pink stuff. Not entirely sure what the difference is between the too....
-Mo
Mo87NA
8
Upstate NY
Thanks Ian. I figured it was something simple. So essentially all Toyota's call for Pink considering you're supposed to have a 50/50 mix to begin with correct?
-Mo
Mo87NA
8
Upstate NY
IJ.;1284326 said:
Yep they actually took it off the market here for some reason.... :(
(I was one of the lazy asses that used it instead of buying distilled water and mixing it myself)
Ahh that sucks. I was lucky enough to find 2 gallons of the Toyota Red on ebay for $15 shipped.
Oct 11, 2005
3,822
27
Thousand Oaks, CA
Here the red stuff is called long-life coolant, is not premixed, and was the factory fill for antiques like the Supra.
The pink stuff is Super Long Life Coolant and is premixed and is the factory fill for current Toyotas. It is HOAT non-silicate, non-amine, non-borate. Honeywell (Prestone) makes it for Toyota in North America.
