Here are pics of the grey car taking best MK3 at SIV 2012.
It was built by Emad at Precision Autowerkz. It was also repainted in 1G0, a Lexus color known as Smokey Granite Mica. Pushes 440 rwhp in LA and was tuned by Shawn Church. It lost 100 rwhp in Vegas due to the altitude and heat.
Engine
Engine Code: 1JZGTE
Displacement: 2,492cc
Turbo: Garrett GT3582R – T3 Frame; 61.4mm Inducer, 82mm Major Compressor Wheel; 68mm Wheel Diameter Turbine; 0.82 A/R Turbine Housing
Exhaust Manifold: CX Racing Manifold Custom Modified by Precision Autowerkz
Exhaust: Apexi N1
Ignition: HKS Twin Power DLI Amplifier
Fuel Injection: Siemen Deka 650cc on 1JZ HKS Fuel Rail
Fuel Deliver: JZA80 ASCO Fuel Pump; Stainless Steel Fuel Line; Fulham Pressure Regulator w/ Gauge
Wastegate: Turbosmart 50mm (Recirculated)
Blow Off Valve: Turbo Smart Race Port
Engine Management: AEM EMS Series II for JZA80; Pheonix Tuning Patch Harness
Cooling: Koyo Aluminum Radiator; Samco Hoses; B&M Oil Cooler
Intercooler: Driftmotion IC & Hardpipes
Intake: AEM
Catch Can: Cusco
Suspension
Megan Racing Coilovers
Suspension Technique Sway Bars (F&R)
Energy Suspension Bushings (F&R)
Driftmotion Subframe Bushings
TSAS Sway Bar End Links
Cusco Strut Tower Brace
Brakes
Brembo Slotted and Cross Drilled Rotors
Porterfield R4S Pads
Goodridge SS Lines
Wheels & Tires
Work Emotion CR Ultimate 18 x 9.5 (-20 Rear, -30 Front)
Nitto NT05 265/35R18
Interior
JDM Twin Turbo R Recaro Complete Interior (F&R Seats, Inserts)
Takata 6 Point Harness; Custom Harness Bar
Momo Jet Carbon Fiber 350mm Steering Wheel
AEM Boost Gauge & Wide Band in LoTek Pod
HKS Turbo Timer
Carbon Fiber Console Lid
LED Climate Control
LED Cluster w/ Stainless Steel Bezel Surround
Pioneer Nav Head Unit, Speakers, Amp
Infinity Powered Sub
Exterior
Paint Code 1G0 (Lexus Smokey Granite Metallic)
Regulus Vented Nose Piece
VIS Carbon Fiber Hood w/ Flush Aerocatch Hood Latch
Shine Auto Carbon Fiber S3 Air Guide
Shine Auto ABFlug Front Lip (Side Delete)
Shine Auto Diana Godfather Fender Flares
Bomex Side Skirts and Rear (Molded)
JDM Hatch Visor, 89+ Tinted Tails, Bubble Markers & Mouldings
![p1903787_1.jpg](https://www.supramania.com/images/pb_archive/p1903787_1.jpg)
![p1903787_2.jpg](https://www.supramania.com/images/pb_archive/p1903787_2.jpg)
![p1903787_3.jpg](https://www.supramania.com/images/pb_archive/p1903787_3.jpg)
![p1903787_4.jpg](https://www.supramania.com/images/pb_archive/p1903787_4.jpg)
![p1903787_5.jpg](https://www.supramania.com/images/pb_archive/p1903787_5.jpg)
![p1903787_6.jpg](https://www.supramania.com/images/pb_archive/p1903787_6.jpg)
![p1903787_7.jpg](https://www.supramania.com/images/pb_archive/p1903787_7.jpg)
![p1903787_8.jpg](https://www.supramania.com/images/pb_archive/p1903787_8.jpg)
![p1903787_9.jpg](https://www.supramania.com/images/pb_archive/p1903787_9.jpg)
![p1903787_10.jpg](https://www.supramania.com/images/pb_archive/p1903787_10.jpg)
![p1903787_11.jpg](https://www.supramania.com/images/pb_archive/p1903787_11.jpg)
![p1903787_12.jpg](https://www.supramania.com/images/pb_archive/p1903787_12.jpg)
![p1903787_13.jpg](https://www.supramania.com/images/pb_archive/p1903787_13.jpg)
![p1903787_14.jpg](https://www.supramania.com/images/pb_archive/p1903787_14.jpg)
![p1903787_15.jpg](https://www.supramania.com/images/pb_archive/p1903787_15.jpg)
![p1903787_16.jpg](https://www.supramania.com/images/pb_archive/p1903787_16.jpg)
![p1903787_17.jpg](https://www.supramania.com/images/pb_archive/p1903787_17.jpg)
![p1903787_18.jpg](https://www.supramania.com/images/pb_archive/p1903787_18.jpg)
![p1903787_19.jpg](https://www.supramania.com/images/pb_archive/p1903787_19.jpg)
![p1903787_20.jpg](https://www.supramania.com/images/pb_archive/p1903787_20.jpg)
Engine
Engine Code: 1JZGTE
Exhaust: Apexi N1
Intake: AEM
Catch Can: Cusco
Suspension
Brakes
Goodridge SS Lines
Wheels & Tires
Interior
HKS Turbo Timer
LED Climate Control
Exterior
