Tough shifting gears under full throttle?
Typhoon
208
ACT
Bleed your clutch hydraulics and adjust linkage for free play. A clutch that does not fully disengage will do all these things, as well as rapidly accelerate wear on synchro rings.
Regards, Andrew.
silvergsx623
WIPLSH & HWY KNG
Oct 16, 2005
498
Alabama
suprafanatic said:
ok this might sound stupid but my car is still haveing problems going into second gear as well.. i would like to try the MT-90.. so my question is where do you drain it and where you do you fill it up..lol
Drain plug on the side of the transmission, around a 20-24 mm I think?
To fill, make sure the drain plug is back in, remove the shifter and fill through the shifter hole. easiest way I've found.
MT-90 can be bought online at summitracing...
it's not cheap (around $50 for the fill), but it's not like you change it every 3000 miles...
aidanair
Cops Love Me
Aug 27, 2007
63
Marlboro
how often SHOULD you get a synthetic oil change on a turbo.. and should i change the oil filter every time? when i changed my oil last time i didnt change the filter cause i couldnt figure out how to get to it.. its like buried up in there
SMP142
BOHICA
Jan 5, 2006
367
Tacoma, WA.
yeah my third gear sychro is going out. but its getting a rebuild for the swap anyhow. my 3200 RPS didnt help out with the prob though.....
the filter is the important part to change
aidanair
Cops Love Me
Aug 27, 2007
63
Marlboro
its too hard to get to! i worked at good lube for 4 months doing oil changes like its nothing... i cant touch this filter! idk how to get to it.. every angle is impossible!
it's extremely simple...
you'll hate it once you figure out out, it's seriously the easiest filter I've ever messed with...
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
new problem...at least i think?
I noticed that while in NEUTRAL, if i press in the clutch and let it out, the car actually moves forward?! I tried it numerous times and was sure it was out of gear....why is this???
