Torn IC Pipe
SupraStorm1080
IT'S A LIVE!!!
Apr 19, 2006
78
riverside, SO cal
Hey, i tore the the ic pipe :3d_frown: where it connects to the turbo when i took out my turbo and i wanted to know if anyone knew a cheap easy way to remedy that or where i could get a new one for a decent price because I am on a budget. THANKS bye
HIDPLANET
89 1JZGTE
Im sure you can contact someone who works on these engines/turbos and they have them handy. Try Aaron from DriftMotion. I recently swapped out my 7MGTE to a 1JZGTE and changed the IC so they might still have parts laying around.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
Get a short piece of steel 2" or 2.25" pipe, cut the stock IC "hose" and use it as a coupler from the turbo to the steel pipe. I actually got a 2.25" elbow pipe from a saab turbo out of a junkyard that happened to be a perfect fit replacement for the stock IC hose, and cut up the old hose to use as a coupler on both ends.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
:werd: Take like two 45 degree bends and mock them up as your new pipe. Use the old rubber hoses as connectors if you want...
mdr40z
arkansas
Home Depot solution works best..... it's a metal electrical conduit ell, all you need is two short pieces of the exist rubber hose to join them at the turb and IC.
SupraStorm1080
IT'S A LIVE!!!
Apr 19, 2006
78
riverside, SO cal
Cool i just probably make a coupler then, because when i Emailed Aaron about getting a used IC pipe he said he had one but wasn't usable on a car so i guess i ll just try to fix the one i have
