Topline engine gasket set
Status
Not open for further replies.
Fozbo
7M Love
Apr 4, 2005
290
Norman, Oklahoma
I was wondering if the topline engine gasket set from importperformanceparts.net is interchangable between the 7MGE and the 7MGTE. I ordered a 7MGTE engine gasket set and when it arrived, the sticker on the actual wrapped pieces says "7MGE". I went back and checked on the IPP.net site and they have the exact same part number for the 7MGE and the 7MGTE engine gasket sets.
I'm just a little unsure if it's just a case of the 7MGE being a base kit that also works on the 7MGTE, or if it is a wrong part.
Any help would be appreciated (tried calling both IPP and topline, but it's Saturday :/).
EdgeSupra
506
New Jersey
I used that gasket kit and didnt like it..my oil seals sucked and had to get ones from toyota, but it did come with the gaskets for the turbo elbow and manifold..next time im just gonna use toyota all the way.
Fozbo
7M Love
Apr 4, 2005
290
Norman, Oklahoma
Thanks guys.
I'm not worried about the turbo gasket stuff, going with full T4 setup.
I actually saw what looks to be a mani > turbo gasket, just thought there might have been some gasket on the NA that had that too.
Thanks for the clarifications.
chriso
Supranian
Bay Area, CA
Don't use the Throttle Body/Upper Intake Manifold gasket from the 7MGE set (the inside diameter hole is too small and restrictive). Otherwise you can interchange almost all of the gaskets there.
Status
