Top Speed in 4th Gear
Fuzz420
Are U Here 2 take My Baby
I was under the assumption that it was around 105mph.Last night i did 110, with a little more room to go.For reference i have 4:30 gear,w-58, and stock wheels and tires.I was going to take it to the limiter but surroundings werent permiting.
Any insight is appreciated
110 in fourth with a 4.30 rearend is insane. Seems like you would be turning about 8000rpm. I could see it with the 373 gears. How many rpm were you turning?....................lol
s383mmber1
3,614
Somers New York
I generally dont look down at that speed, nor do i usually go that speed.
But-
I can go well over 100 in fourth with room to go.
I have a NA w58 with 4.3 LSD
Fuzz420
But-
I generally dont either but i had a challenger arise, so i sped up to catch up to him, did a quick speed check seen i was going a 110, and decided not to jump lanes to follow him around some semi's and slowed back down.
HellsLegion said:
Yup. Around 110.
is this with an pre 89 ecu or 89+.
inline6
Whistle>Whine
Sep 22, 2005
208
SoCal
I have a 4.30 rear end on my 1j and I can get to 90 in 3rd so I know 4th is good for well over 100. I have a r154 but I believe 4th gear is 1:1 for both tranny's so it doesnt matter. 110 you are gettin close to the top of 4th tho. Search online for a calculator and it will give you MPH ratings for each gear based on diff, tire height, gear, and RPM.
Fuzz420
HellsLegion said:
Im 89+
My 7mge will do 90 in 3rd,around 93-5ish the limiter kicks on. Ill try and find one of those caculators and see what it has to say.
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
Texas Motor Speedway
I did a pull the other night in 4th, punched it, was at around 100 by 5kish. I'm sure it still had some room to go, I could see it hitting 110. BTW this was with a 4.3 rear end with a W58.
-Matt
8,898
Speedo's are built optimistic. 6000 RPM in 4th with stock tire diameter and 4.30 rear is 102.57 mph.
5th is 131 at 6000 RPM.
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
Your speedo is off. reading fast.
4.30 rear, W58 trans, stock 225/50/16 tires.
RPM = MPH
5000 = 85.9
5500 = 94.5
6000 = 103.1
6500 = 111.7
The equasion is (tire circumfrance X eng. RPM)/(1056 X trans ratio X axle ratio) = MPH
s383mmber1
3,614
Somers New York
89supturbo said:
supras came w/ 373's, they can go mugh higher than that on stock gearing
Certain supras came with 3.73.
My supra, and many N/A's came with a sport package which includes a 4.3 limites slip differential.
