Tis how we do it Down Under!.. project 7MGTE (now running YAY)
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
JayRome;1444285 said:
interesting name for the adapter :p
i didnt take many photos of the cold side cooler pipe as its really really short. it comes out of the Evo6 cooler into a perfect U bend then 90deg straight up.... if you can picture that.... also the car has no A/C soo the fan on the battery side has been mounted in front of the radiator for clearance....
car will be hitting Dyno in a few weeks i hope (if they have space for us) i know some of you out there are waiting for dyno graphs from this build....
Ahh. I was going to be damn impressed if you made it "magically" clear everything in the way. Still, great job on simplyfying something like this. Going to have to talk to Sethron for those alternator brackets and move the battery to the back.
supramk3
sleeper
Apr 6, 2009
32
queensbury
i almost did the same set up but i took out the freeze plug in the front and dremeled the whole bigger and tigged a 3" alloy pipe on the end and made a plate for th throttle body and made a block off plate were the throttle was. good idea i didnt even think of that at all
JayRome
Melbourne
www.team4g.com
soo its been a while and it finaly got a Tune this morning.. due to the rediculous heat down under, we had only a light tune today....
all my work paid off...... going for second tune after cooling system problems are solved....
229kw @ 9psi.... soo who likes lag? ....
