tires
corylee316
until it goes boom
Aug 17, 2006
125
Moscow, IA
I still have the tires that came with my car. They are a brand that I haven't heard of but they hook to a point then are gone. They never squeal, all I get is traction then it heads for teh rev limiter faster than I can let off the gas. I was just wandering what everyone else is running for street tires. I'd like more traction before they let go but don't want to spend tons of money. Any help would be nice.
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
I am running Kuhmo Ecsta MX's
Check out the rating on Tire Rack. they don't rate every single tire and don't carry everything but it help to give a good idea of how certain tires perfom comparied to others
http://www.tirerack.com/tires/tires.jsp?tireMake=Kumho&tireModel=ECSTA+MX
their #2 in there Catagory = Extreme Performance Summer Tires according to Tire Rack though. So who knows. They are a advanced silica, rubber compound
suprageezer
778
Southern California
Goodyear Eagle F1 GS-D3 245-60/16's here also, nothing like them, before you buy read all ther reviews on any tires your thinking of buying at tirerack.com. I got my goodyears at discount tires for 151.00 each. Never go cheap on tires they are the only thing between your ass and the road.
bobiseverywhere
bobb'n for money
Montreal
is that a typo
245-60-16 would be a tire that is to big for the car a 60% side wall on a 245 tire is larger then the stock diameter of the tire or what the tires should be.
For example 225-50-16 is stock if you went 245-45-16 that would keep the same size basicly just a hair shy of proper wheel size
I run 235-45-17's
235 is the width of the tire
45 is a Percentage of the Width for the side wall hieght
17 is obviously the rim size.
Edit i edited the OEM tire size made a typo myself
Brewster
So it goes.
Apr 15, 2005
1,156
Morgantown, WV
honestabe said:
Don't buy the Falken Ziex 512's unless you want to drift. The tires are rock hard and I break my rear end free constantly with them. I don't think I'll have that problem with the Goodyear Eagle F1 GS-3D's, wet or dry.
or it could be how small your tires are... wtf
MKIIINA
Destroyer of Turbos
Plano, TX
Goodyear Eagle F1 GS-D3 245-60/16 or Bridgestone Potenza's
the bridgestones on my old na were awesome. only complained when pushed at 9/10ths, wore great, when traction broke it was very gradual and controlled. i miss those tires :(
currently run futura ultra z's and they are a great cheap tire with loads of grip and they wear wonderfully. 10+ drag passes and they still look great but i think they are a touch too hard overall but might be its more power in the same tire size.
bobiseverywhere
bobb'n for money
Montreal
you guys need to learn something about tire sizes. It does affect your spedo, your tranny, Engine and Differential.
either way be careful about the size of your tire selection and make sure that it is the correct diameter according to what woud be there regardless of what your rim size is
RHDMK3
that's it!
Sep 30, 2006
447
Salem, Oregon
I say get some Dunlop Direzza's. Its a good tire that seems to be pretty popluar over here in Japan. I'am personally rockin' Falken 512's on my ride and am pretty pleased so far.
