Tire pressure
mtx911
Permanently Banned
Nov 2, 2009
47
calgary
Whats the recommended tire pressure for the ma70 89 supra turbo supra.
i checked the door jams and passenger nothing their says anything about it.
i read 30 psi on 51 psi max tires, the tires kinda lump at the bottom.
what shud i fill the front and rears up to??
airhead04
1,489
Lima, Ohio, United States
I think you should go with what the manufacturer suggests. But I have tires with max psi at 50, and i keep them at 45.
mtx911
Permanently Banned
Nov 2, 2009
47
calgary
Tyre Pressure, kPa (kg/cm² or bar, psi)
Conventional Tyre
225/50ZR16
Over 210 km/h (130mph)
For all loads including full rated loads (4 or 5 passengers)
Front 300 ( 3.0, 44 )
Rear 320 ( 3.2, 46 )
For reduced loads (1-3 passengers)
Front 260 ( 2.6, 38 )
Rear 280 ( 2.8, 41 )
Under 210 km/h (130 mph)
Front 270 ( 2.7, 39 )
Rear 290 ( 2.9, 42 )
Front 230 ( 2.3, 33 )
Rear 250 ( 2.5, 36 )
i don kno which one to go with, its usally only single person in car.. so
the 1-3, 38 and 41 psi i shud do??
Failure14
276
Ohio
There should be a sticker when you open your glove box....
Atleast there is on my 90T.
And it says 35psi.
Also it depends on what your doing...
mtx911
Permanently Banned
Nov 2, 2009
47
calgary
Yeah well i notice that when i turn the steering blows like it feels like my tire is going over a bump or something but its just itself lumping over..
so around 42 front 44 psi back sound good?
mtx911
Permanently Banned
Nov 2, 2009
47
calgary
whats the downfall of tires that are to close to the max, not that i intend but
if for some reason 42 and 44psi are to much or to little whats the downfall on each side?
they should be anywhere from 32-36. the more pressure the less traction and more wear in the middle. less pressure more traction and more wear on the outside edges.
just because your tires say 44max does not mean thats what they should be at.
35psi is the spec from toyota.
i run mine at 32 stock size tires.
airhead04
1,489
no one said 44 max. 51 max yes.
Go with what feels the most comfortable.
a lot of tires its only 44. was just a example as every tire is different.
either way its not recommended by the tire manufacturers to run your tires at its max psi.
airhead04
1,489
Lol, no do not run them at max psi. Unless you plan on drifting, I believe they do.
mtx911
Permanently Banned
Nov 2, 2009
47
calgary
where the hell does it say the recommnded tire presuure on the car cuz i check door jam and nothing, the manual gives me 5 diffrent pressures, one with 1-3 passengers, one with 5 passengers i dont know man,, its usually only me in the car but it doesnt help wheres it located on most supras?
the one with 1-3 passengers. our cars are only a 4 seater including driver so 5 is out of the question.
35psi
