Today I started to sand down a few rust spots on my car that were starting to bubble behind the paint about the size of a dime (rear 1/4 panel). Aftersanding down, then cutting away some of the metal (about 2" long and .75" high) to get all the rust out I used a wire brush, sand disk, and rust converter to remove all the pits and rust off the surface. When I was completley sure that all the rust was gone from both side of the panel I sprayed it with automotive rust primer (Tremclad) to reduce the chance of it coming back in the near future. The rear quarter had a rather thin sheet of metal then a hollow space and a much thicker/stronger metal behind it (im assuming it might be part of the frame.
My question here is, should I just Bondo the 1/4" gap between the outter 1/4 panel and the metal behind or should I use a metal mesh screen between the 2 panels and then bondo over the mesh?
All thoughts and opinions are appreciated.
Thanks,
-Dan
Thanks,
-Dan
