Tips on storing machined block, head, crank over winter
leftynridge
401
dayton, ohio
Well I finished all the machine work for my rebuild about a month and 1/2 ago but do not plan to put everything together until spring. I would like to know what would be the best thing I can do to prevent any rust until then. I have soaked it down with wd-40, placed plastic around it, and put it in the house inside a box. I would like to think that I'm doing everything I can do to prevent rust but I would like to know if any of you have any other tips.
MA70L-BJMVZA
11
Virginia
I did the exact same thing as you to store some engine parts, but wound up with surface rust on them. I think the WD-40 evaporated, leaving the surface unprotected. I switched to coating the parts with 30 weight engine oil, and have had no surface rust since that change. Good luck!
ul
Chaingun
285
Mooreland OK
So....basically you use an extremely hard to remove wax like substance wrapped in a retardedly versatile plastic? i must say i'm a bit confused lol, i am interested though in what type of boPET you'd use and how to remove the Cosmoline after it's been applied
leftynridge
401
dayton, ohio
Now are you guys just talking about the cylinder walls when it comes to coating with 30w oil. What about like the oil passages and coolant passages?
Chaingun
285
Mooreland OK
obviously you can coat the oil passages lol, TBH i've never though about the water jackets, usually put it on a rag and wipe it on, and a flush the cooling system when i finish building the motor
leftynridge
401
dayton, ohio
Thanks for the advice guys. I thought I was doing just about everything that could be done to prevent rust but I figured it wouldn't hurt to ask. After all it would be a shame to allow $1600 worth of machine work go down the drain because I simply just didn't ask.
Oct 11, 2005
3,822
27
Thousand Oaks, CA
Although the grease is a pain, it is pretty much idiot proof. The plastic can get you into trouble if the wrong plastic is used, or if the humidity is not managed inside the bag. Standard plastic bags and such are often porous to water vapor, and a desiccant along with a humidity sensor tag is needed to ensure things remain under control. Hence the use of mylar, and vacuum packing. Just throwing it in a bag will likely not end well, especially if the temperature swings around.
