timing setting
ariel4946
toyo maniaco
Jun 5, 2006
24
puerto rico
I recently bought a 88 supra with a bhg ,i buoth a felpro gasket rectificate the head and passed the presurised test,but still have problem with the overheat .i notice that the time is not the correct because I try to set in 10 d but i cant.the time is over the 15:1zhelp:
IHI-RHC7
"The Boss"
Oregon
Your exhaust cam is one tooth too advanced, you need to take off the front black cover and retard the cam one tooth, (turn it counter clockwise one tooth)
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
^^^ Yabba... Also for giggles, check your codes. Code 51 can make it hard to set the timing, but I don't think that will explain the overheating issue.
ariel4946
toyo maniaco
Jun 5, 2006
24
puerto rico
i recheked the timing marks and its matched perfectly
