timing Q
MK3less
Money eating monster
Jun 3, 2005
68
Mass
ok so i replace the CPS on my car and I whant to know what do you guys your timing set to is it to stock like the TSRM or do you have it more adv or retarded. Thanks
MK3less
Jun 3, 2005
68
Mass
ok. I see so everybody is running the stock timing.has anybody try adv the timing to see if it gains any with out pining
E
Eddie the Eagle
Guest
the ECU always thinks the timing is set to 10deg BTDC
if your engine is worn and needs say 3deg advanced the ecu does this however still reads 10deg BTDC when you put your strobe on it, so if you advance your engine to 15 you could efectivly be running 18-20, its up to you.
shane87turbo
yea it used to run 12's
Apr 4, 2005
13
coco crispies ,tx
to make it easier on you
jumper the diagnostics box e1 and t1
set timing to 10 via the cps
tighten the bolt down
take out the jumper wire
and itll bump to 12..which is where you want to be.
