Timing Belt Tensioner Spring Ratings
rfurgy
73
Franksville, WI
Would anyone know what the T-Belt spring is rated at?
I found that the overall length is 69mm but can't seem to find anything on it's max load or other ratings.
Thanks.
rfurgy
73
Franksville, WI
1) Parts for this car/engine are becoming hard to find
2) I'd like to be able to source this simple part from other suppliers than Toyota
3) I'd like to get a spring with a hair more tension
suprarich
Guest
Nov 9, 2005
2,187
ohio
Yes, the spring does nothing. The bolt through the center of the pulley holds the tension on the belt.
