Timing Belt Replacement. What Other Parts?
landtoy80
146
grand junction, CO
I have a belt and cam seals.
What other parts should I replace while in there? Front main seal, internal t-belt parts, water pump???
Tools I will need to get torque wrench and chain wrench. I have a puller and can rent one if mine doesn't work from parts store.
It's the Oil pump drive pully, You need to remove it to change it's seal, If you do it with the Belt in place it's no problem as it's not a high torque setting.
A lot of people jam a wrench/screwdriver in to stop it turning and mark up it's arms this leads to failure of the pully.
Frank Rizzo
478
Fixing your girl's car
I'd replace the water pump before you install a new timing belt.
When you pull the water pump, coolant will gush all over the timing belt covers. There is a seal on the top and sides of the plastic cover, but where the plastic and aluminum covers meet, it will seep into. And we all know coolant on timing belt = bad.
