timing answer please.
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
just a quick question. when i adjust the timing on my 1g i have to jumper the diag. block right? aka limp mode. ok its supposed to be -10btdc well it was like -18btdc so i set it to -10. when i remove the jumper from the diag plug should it still read -10 when i shoot it with the light? it was set perfect at -10 jumpered but when i remove the jumper it goes to like -15. am i doing something wrong?:1zhelp:
souprat
fairfax VA
no, your fine. the ecu has full controll over timeing and it adjusts it how it sees fit. you are only giving the ecu an idea of where to start, sortta. so you set timing when jumpered, and then when you pull your jumper out the ecu takes over and sets the timeing from then on. it will only read -10 when you have it jumpered. or in a situation that the ecu deems it nessisary to have -10deg timeing. but in that situation you will be driving the car and not sitting there with the timing light watching your crank.;)
1g= the dsm kind of 1g?
8,897
aka limp mode.
No. Diagnostic mode.
Limp mode was used for a short period of time, but caused pollution, the one thing it was trying to stop. Limp mode was used when a critical input was lost, so timing and injector duration were set a fixed levels.
Topher E
Trance Head
Aug 4, 2005
388
Vacaville
Ive always know it as back up spark and fuel.
*Feels he needed to voice his oppnion for no apparent reason*
8,897
Nothing wrong with voicing an opinion.
What do you mean back up spark and fuel? You are not supposed to drive the car in diagnostic mode.
