time to cry more supra probs
Shima
I'v got Supra powers
May 23, 2007
215
carlisle
So i got the car back from toyota today £498 bout $900 down she starts she runs WOOOOO untill i drive her home.
i only live 2 miles away so i took the 10 mile run just to see how she is. i was driving nicely no hardness. and the temp didnt go up at all. and the oil pressure went out of the guage just driving at 50-60mph all the way. the bad thing is it still rises even at idle and the rad still has god damn compression in it. no water is comin from the rad cap or overflow but UGH.
heres the oil guage :aigo:
any light?
cheers
Shima
May 23, 2007
215
carlisle
hehe i didnt say it would did i? these are just all the problems but bad sender hmmmm interesting. i'm gonna have a rundown of the car tomorrow with a friend piishin me off now it went in for a hg in july and i'm still feeling the backlash from it
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
cheers
Sounds here like you did but it's just the way it's worded.
Shima
May 23, 2007
215
carlisle
cars runnin fine compression in rad is now gone just needed bled erm still got the oil pressure problem but theres not any in the actual engine it just seems to be the guage and the water temp guage not working either.
Shima
May 23, 2007
215
carlisle
yea comes down when car is off then when ignition is put back on there it goes again straight back up (thats after it goes up idling for a while)
Loki
The Future is Unwritten
Prince George, B.C.
My temp gauge would do that (peg the gauge), it was something to with the gauge/wiring/sender as I hooked up an aftermarket one and it was reading perfectly fine.
Shima
May 23, 2007
215
carlisle
oh yea another thing is my dipstick seems to be stuck and won't come all the way out. any idea's what would be causing this and how to get it out?
also was thinkin aftermarket stuff :)
CPT Furious
Now MAJ FURY!
KDOV
I'd also check to make sure your oil pressure sender line isn't grounded. Mine grounded out, drove the needle all the way up, and made the needle move off of the actuator so it stayed pegged all the time. I had to take the cluster out and disassemble and put the needle back on.
Might be worth checking to see if that wire is grounded on anything or not...
Shima
May 23, 2007
215
carlisle
yea man erm heres the list
vacuums
both inlet gaskets
throtle body gasket
cold start injector (new one installed &#163;80) < :O
6 new plugs
erm air hose cleaned and just everything tightened.
erm oh and ISC valve
