Tightening my crank bolt...
dunnbeetle
119
Bemidji, MN
I'm putting my engine back together and the crank spins freely until I put the crank pulley on. When I take the pulley off and just put on the crank bolt it spins fine. the torque wrench I am using only goes up to 150 but when Im tightening the bolt with the crank pulley on it, the crankshaft doesnt even turn, and I know its over 150 ft lbs...need help asap as im working on it right now. thx.
dunnbeetle
119
Bemidji, MN
so i guess when i put the crank pulley on it really f'd up the idler gear...I have a spare one of those....but it also put a hairline crack right on the bottom in the middle under where the front crank seal goes....any suggestions on what I should do now? would jb weld hold? I really dont have time tear it all apart again because im using some1's garage and they want it out.
Mrbaboon
277
Victoria, BC
starscream5000 said:
Try to stay away from using JB weld anywhere near the engine ;).
What I enjoy is a member who's name will not be mentioned because he is supposed to have a fairly good reputation and is trademarked by lack of spelling's idea to use JB Weld to fix pitting in a block.
Winner idea.
:icon_mad:
GET A NEW COVER. Its a pain in the ass but you DON'T want leaks there.
Mrbaboon
277
Victoria, BC
IJ. said:
Shhhhhhh. You weren't supposed to guess.
JB Weld ftw!
(Maybe I'll use it to tap out that new oil pump mounting hole, but thats a different story :icon_razz, no I'm actually gonna tap it M8x1.25 )
