throttle linkage help!! n/a on turbo cables?
demolition man
ct
alright im hooking up a 7m-ge in place of an tired 7m-gte, everything is done except the trottle linkage and kickdown cable for the tranny, i think the trottle cable is quite a bit shorter on the turbo engine, what types of linkage or cables will i need to make this work? here a pic of the type of trottle body. i might be able to modifie the cables to work but any help would be greatly appreciateed
soory this was the best pic i had
thanks
cuel
1,536
Baytown, Texas
What is the throttle body off of? It doesn't look right...
Edit: I tried to find a good pic of the n/a t.b. linkage, but don't have one. If one doesn't get posted tonight, I'll snap a couple for you tomorrow.
Kckazdude
1,239
Memphis, TN
I didnt think that looked very familar to me. Thanks for the tip BWB.
From the pic you posted it looks like you will need N/A accelerator cable linkage from a Supra to make it work.
demolition man
ct
i am going to need a realy long trottle cable i guess because it runs to the trottle body from the passanger side of the car? will a normal ge throttle body hook up in place of the one with traction control?
