Throttle Cable Questions
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
Prepping for FFIM install soon. I have a few questions.
How do I remove the throttle cable? Is there any DIY pages here with pictures. Or if anyone has knowledge of the step by step process?
*Edit* I was able to remove the 2 10mm bolts on the bracket securing cable running thru the firewall. What is the final step to taking the cable out and setting up the new cable?
Secondly, are there any implications if I lock the transmission cable down to where it would think its full throttle at all times? I am thinking of ways I can hook this up to the throttle body with no luck..as the oem throttle linkage cannot be utilized anymore.
All help/ideas are welcomed.
Thanks
You will need to get a longer kick down cable. Point of it is to down shift when you open full throttle.
