this ones killing me.please help me
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
My cars sit in the drivway and is not on the road it will be soon.Ok so my car was running great last week.I took the battery out to get a parts car i was going to buy started nothing worked turned on in the parts car but anyways what this is all about is I put the battery back in my car and it started but it idles real low and the shuts off and it seems like theres no battery power,I need to hold the gas for the car to stay on.So i charged it 3 diffrent times and it ran the same so i checked the alternator and it was good and I went out with all my money I had and got a new battery and the car runs the same.I have now check engine and I looked at all my fuses.I even looked for a i/c leak but nothing.Please let me know what this might be or if this has happend to you.
romaniello
94
Sanford, FL
I don't have an answer for your problem but I want to clarify something; the only function of the battery is to start the car (or run accessories when the engine is not running), once the car starts the alternator takes over and the battery can be removed as it then becomes a load to the charging system. So... if the car "idles real low", the problem is not the battery.
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
Ummmmm if the battery dose not have a good charge to it it will idle low.
johnathan1
Supra =
Aug 19, 2005
5,056
That's not a good idea ^^. (unplugging battery while idling)
Check your codes first. Will probably throw a code 11...make sure the battery terminals are very clean and tight, and making good contact. If they are loose, it will act how you are describing.
Hopefully you'll be able to return that extraneous battery. :)
willfish
been here since 2003
Apr 23, 2005
648
Pittsburgh, Pa.
i;'m almost 100 % i know what ur prob is,,
when you disconnect ur battery teminlas, something about the ecu has to reset itself,, so when you plug it back in your will get low idle till the ecu resets..
it happens to me everytime I disconect the battery,,
an yes it stals on you a even if you give it gas huh ,, like you gotta wait a good 15 min or so till ur idle goes back up...,,
its not ur battery...
Will
cuel
1,536
Baytown, Texas
^^ There's your answer. It needs to relearn the idle without the throttle open. If it stalls, just start it again and let it idle until its warm. Usually mine resets within a minute or 2.
willfish
Apr 23, 2005
648
Pittsburgh, Pa.
Rennat said:
Might also be the alternator fuse... that was the problem on mine...
,, maybe,,
but, I'm like 100 %,,, on this one.. I got a short somewhere in mine an I'm too lazy to look for it , in order so my battery dont die I disconnect the teminals after every night of driving the ride, an obviously every day wne i re connect them my idle is low plus I confirmed it with a friend in the next city over that expeirenced it too...
Will
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
Thanks guys I'm going to try and let it run for about 10-15 minutes like you said.OO and it's not the alternator fuse because I checked that last night.yea I know working on my car on thanks giving lol I should be watching a foot ball game or somthing
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
ok so I let it run with out giving it gas for about 20 minutes and it runs the same i started it right after to see if it was fixed but it still runs the same any other ideas?I'm thinking of getting new battery terminals my negitive looks alil beat up.so let me know what you guys think.
Kckazdude
1,239
Memphis, TN
romaniello said:
Try this:
Start the car
Remove the battery while the car is still running
Does it idle different?
Not the smartest thing to do but if a different idle is all you get out of it, you should feel lucky. A discharged/shorted battery can cause all sorts of problems.
Ish
SM Pimp
Socal
You said your check engine light came on. Have you checked for codes? Have you tried adjusting your idle?
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
now befor i start driving it/leting it run should i disconnect the battery again to start it all over or just leave it?
also there is no check engine light
