Thinking about changing to emanage blue
Did you install the Stinger Standalone yourself or did you have someone install it? That's going to be the next purchase I make for my car. I know my afc is messing with my timing. I"m having to pull almost 50% of fuel at 4000-6000 rpm's. My injectors are too big for the stock ecu I guess. I was just wondering how hard the Standalone was to install if you're not a wiring guru.
rakkasan
Currahee!!
Fort Campbell, KY
I put it in myself. It was easy to do because Aaron supplied the plug & play harness. The only trouble I had was getting the laptop to connect to the ECU so I could load the tables, but as always, Aaron saved my bacon over the phone. I had loaded a set of drivers for the USB - serial cable adapters, but it was the wrong ones. After I reloaded it with the correct adapters, the laptop connected to the ECU right away.
With the 440cc table that Aaron gave me, it cranked up with a little coaxing. I trimmed the fuel a little, bumped up the idle & the car ran well enough for me to drive it to Atlanta today (110 miles) so I can get it tuned. Funny part is, even though it isn't near 'tuned' enough for my motor, I got a lot better gas mileage than the stock ECU. Go figure....
All in all, I'm excited to see the difference. The tuner is a well respected dude around here. I talked to him about the direction I wanted him to go (broader power band, more torque, faster spool) & he said that it would be no problem. I fact, after telling him what I would be happy with power wise, he just chuckled. I'm have a feeling that I'll be surprised, but I don't want get hopes up just yet.
My advice, bite the bullet & make the switch. I would have done it when i shipped my car to Aaron had i know that it was available a little earlier, but I had already dropped a lot of coin on my EMB set up.
If this tuner is in Atlanta, then I could just drive over there. It's only about two and a half hours away. How long did he say it would take? The way you typed it, it looked like you were going to have to leave it for a while. Thanks for the info.
rakkasan
Currahee!!
Fort Campbell, KY
The shop I took it to is Mainstream Performance. I left my car with them on Sunday because I flew to NJ on Monday & I won't be returning until tomorrow. I had them put the 2J cams & HKS cam gears in too since I don't want to have to have it tuned again & I didn't have the time to do it myself like I thought I would. I just talked to the guy there to see if it will be ready to go tomorrow. He had just got the car on the dyno an hour before I called so he had some time to get some of the tune done. He asked me several questions about how I wanted to have the car tuned & also what the car will be used for. All in all I'm really happy with this shop so far. They are setting my car up for what I want (power band & torque), not the way they want it...
Oh, the early word on the difference.....go here
