There are always more questions>>>>>
Wendigo
Ericsplosion
Jul 25, 2005
331
New Paltz NY
ANd these are mine:
1. Can the manual transmission be filled from where the shifter mounts?
2. What is the preferred tranny fluid?
3. Is there a preferred clutch/PS fluid?
4. Where does the heater VSV get it's vacuum source from?
5. Does anyone have a petcock that they're not using?
6. Is there an ideal place to mount the battery cable ground (negative) to the block?
7. Is there a preferred location for the remote oil filter mount?
I'm sure there's more, but these are a good start to whipping my beastie into shape. Thank you, Eric
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Wendigo said:
ANd these are mine:
Yes
85w90, std or synthetic
Clutch fluid, I use dot4 brake fluid. PS fluid should ALWAYS be ATF
From the back of the intake mani, 1/16" nipple
Napa auto does...
Yes, there is a flat spot towards the front of the block, drivers side, right above the oil pan next to the motor mount
Don't know
shaeff
Kurt is FTMFW x2!!!!
11
Around
#7, most people mount it below the passenger side headlight, fogligh assembly. that's where mine is.
-shaeff
Wendigo
Ericsplosion
Jul 25, 2005
331
New Paltz NY
Oil cooler ?: I have a Koyo radiator with an auto tranny fluid cooler inside but am using a man trans. CAN I use this cooler for engine oil instead of purchasing, plumbing and installing an aftermarket cooler?
