I've heard that this can be done:
Replacing stock headbolts with ARP head studs (and tourqing to the standard ARP spec) by threading out the stock bolts one by one in the tightening order, and replacing each bolt with a stud and tightening it down (to the same as what the stockers were, then tightening them all to spec once they're all replaced) until all the stock bolts are replaced with ARP's.
I do not have a BHG on my 7M-GTE (I can check the compression numbers, if that will help). I changed the oil last week and it's still clean... coolant is still looking good as well, changed it a month or two ago... But I don't know what's between the head and the block... I don't want to waste money doing a complete rebuild on something that doesn't need rebuilt, but I honestly don't trust the head gasket as far as I could throw the engine... I do not know anything about the history of the engine. It's supposedly a JDM swap with about 20000km on it. My assumption (and what I've been told) was that it came out of a crate, off a pallet, and under the hood, just before I bought the car. Previous engine may have suffered rod-knock.
If it ain't broke, fix it 'till it is, is generally my motto. The motor pulls amazingly strong and solid, runs smooth, has zero hesitation and sounds amazing. It burns a bit of oil on startup (stem seals?), but other than that there's no reason to rebuild. But, I don't dare turn up the boost past a bit more than stock for fear of blasting the head gasket out the side of the block.
So, would swapping out the stocker head bolts for ARP's as discribed above be risking distruction, or would it be a good idea to get some reliability?
