the six rear subframe bushings
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
78
Atlanta
I bought a set of nylon bushings from Becauseican, but they are too harsh- let in too much rearend noise.
I plan to cut them to half thickness and just use them as shims for the stock bushings.
enjoi.this
Formerly ChrisC
Aug 18, 2008
674
Kelowna, BC
I bought the nylon ones from bicperformance also. They do transer in some rear end noise but they worked great to reduce wheel hop and shimmy on hard corners.
enjoi.this
Formerly ChrisC
Aug 18, 2008
674
Kelowna, BC
montego6500;1702769 said:
So do u think if I got just the spaces I wouldn't have to change the bushings in the subframe itself or should I do that anyway
Sent from my HTC EVO using Tapatalk
Its much easier to just put in the spacers. Sub frame bushings are time consuming and a bitch to do at times. I only did the spacers and was happy with the improvements.
