the radiator thread
MA717MGTE
boostaholic
Apr 2, 2005
404
Bristol VA
well i was looking for an older thread that people discussed thier aftermarket radiators.
can anybody point me in the right direction? i searched but couldnt find it thx.
SPD TRP
Formerly 3rdtimearound
Apr 12, 2005
526
Katy Texas
Got the Koyo in the group purchase.
Like it alot, great quality in form and function.
How about responding to your pm's?
Wayne
supraman7mgte
Shut up,bitch!!
Sunny California
just dont re-use the stock shroud as it wil get sucked into the fan and ruin your clutch.the added thickness of the radiator kicks the shroud closer to the fan,eh? i learned this the hard way!
supraman7mgte
Shut up,bitch!!
Sunny California
this is true,but by adding a thicker radiator,the fan-to-shroud ratio is different.
when i did mine,the fan actually sucked the bottom part of the shroud over 4 of the blades. i toasted a perfecly good shroud due to this oversight.
thats why i went custom and made my own shroud. before
new style
mkIIIman089
Ohio
There are no issues. He just did something wrong.
I drove several thousand miles with my PWR, stock fan, and stock shroud. Needless to say... absolutely nothing went wrong.
had to bring this thread back... I need a radiator and I'm leaning towards the Koyo, but supposedly it's not a direct drop in. What mods do you have to do to get the fan shroud to mount up right?
help is much appreciated...
dugums
Better, Faster, Stronger
Apr 10, 2007
699
Chicago, IL
The only "mod" for a 7m is that there is a threaded hole in radiator for a 1j temperature sensor that you must put a bolt in (preferably with some loctite or something). I can get you the exact size in the morning.
EDIT: you need a 16mm x 1.5 drain plug
dugums
Apr 10, 2007
699
Chicago, IL
Poodles said:
thought I read that the shroud doens't fit right?
gonna have to get a koyo now...
Shroud fits easily on mine. Just make sure the bottom portion is secure. Should fit fine on others as well.
Sl1dewaysSupra said:
I have had the CSF radiator for about two months now with no problems. I rarley see the temp reach half way.
got an old stoc replacement CSF, it's seen 2 BHG's so I'm thinking it's going bad (looks pretty bad in it too)
