The early report from the dyno with Stinger....
rakkasan
Currahee!!
Fort Campbell, KY
I just spoke to the guy tuning my car in Alanta. After only one hour on the dyno, he said he had all of the drivability issues worked out & he just had a pull of 440whp at 13psi :aigo:. He's going to continue working on the base tune, then start tuning the the timing map to get the turbo to spool earlier than before (full boost at 4300rpm). I asked what he thought the results would be & he said full boost should hit around 3300 - 3500 & the max whp should be at least 480, maybe over 500. I guess stand alone & 2J cams are a decent upgrade.:icon_bigg
Previously on stock cams & Emanage I hit 426whp@20psi, so I could see a gain of 75whp with a much broader power band & a lot more torque...
OneJoeZee
Retired Post Whore
aboard the Argama
I don't know when I'll step up to a standalone but you just reminded me I still need to buy cams in the future. God damnit...
Oh, nice numbers. 440@13 is kickin ass. :D
rakkasan
Currahee!!
Fort Campbell, KY
HIDPLANET said:
Thats awsome man.
I cant wait to go standalone.
Thanks dood, I recommend Stinger to anyone that has a 1J that is thinking about buying a simple AFC. Sure, you can save around $500 by buying a SAFC, but you're still face with the potential ECU failure & you get a lot more power from your motor...
My .02
rakkasan
Currahee!!
Fort Campbell, KY
I like what I've heard from the tuner so far, I can't wait to drive it!
Boostage
323
Florida
good numbers, Im gonna run aem or Motec. but Im still deciding what turbo Im going to run. probably Custom spec.
rakkasan
Currahee!!
Fort Campbell, KY
Unless you're going to run the piss out of it, save your money & go with the Stinger. The shop I took the car to is mainly a honduh shop, so they've never seen the Stinger (not that it's limited to Supras) & they are very impressed with it & the software. I am too! The guy that's tuning my car said that he thinks that it's easier to tune than AEM....
Boostage
323
Florida
so he never seen it before but was still able to tun it? that means software interface fairly simple then?
rakkasan
Currahee!!
Fort Campbell, KY
Never used it before, I supplied him the software. HE likes it that much, and he's tuned quite a few different ECU's.....
rakkasan
Currahee!!
Fort Campbell, KY
IJ. said:
Most ECU SW is much the same once you figure out the Syntax and terminology used :)
Great results so far Mark you should be happy!
I am happy, not bad for a weed eater, right?:biglaugh: Thanks Ian, good to see you around too!
p5150 said:
Good results - congrats on a positive outcome with your swap and upgrades!
Thanks dood!
rakkasan
Currahee!!
Fort Campbell, KY
driftking786 said:
what mods?
sweet numbers:love:
60(ish)mm 60-1 garrett with a .58 rear housing
USDM 2J 550's that were cleaned & rebuilt, yet flowed 450cc :icon_conf
aeromotive AFPR
Walbro 255
2JZ cams
12x24x4 FMIC with 2.5" hardpipes
Tial BOV & wastegate
Profec E-01 boost controller
Stinger Stand Alone ECU
OneJArpus
2,798
My .02
i guess i'll have to sell my sard ECU to offset that 500 difference to 50/100 =P can't wait to go standalone, Cams & twins or single upgrade first thing the rest will follwo
