I've been trying to figure out my rich idle (mid 10's afr when warmed up) :1zhelp:
I checked for codes and found none...
I did the three tests listed here, http://www.supramania.com/forums/showthread.php?t=39856
Results of each test in red...
1. Oxygen Sensor Feedback Mode.
* T1 and E1 Connected (In the diagnostic block.)
* Engine Running at 2500 rpm
Result of Ox sensor signal processing:
0v=Lean or Open loop condition
As soon as the throttle is pressed it goes to 0v and stays there.
When I let off the throttle it takes a bit and then reads 5v.
AFR is in 10 to 11 area during this test.
_______________
2. Diagnostic Mode
*T and E1 connected
*Engine off
Results of Diagnosis:
5v=Normal, No trouble codes stored.
________________
3. Learned Value Mode
*T and E1 not connected
*Any operating conditions, RPM's, or speed.
Constant 2.25v
AFR is in 10 to 11 area during this test also.
________________
I know rich idle can be many things so I was hoping the vf results could start me off in the right direction on what to check next.
Any ideas on what to do now?:1zhelp:
_______________
2. Diagnostic Mode
*T and E1 connected
*Engine off
________________
Constant 2.25v
________________
