im sure some have you have read the superstreet issue for this month but id like to post up the tips so here ya go.
10. change your dried out radiator hoses
9.verify the fan shroud isnt cracked and is sealed properly
8. check for a leaking radiator cap
7. inspect pulleys and belts
6. change the thermostat
5.make sure your fan is in good working order
4.use washers to raise hood for ventilation, or get a vented hood.
3.flush old coolant
2.replace the water pump with an electric water pump
1.swap out the old radiator
well theres the ten ways to help keep your car from overheating during the summer, and maybe if your car is over heating, theres ten things to think about doing to keep it from overheating.
*ten ways to help prevent your car from overheating courtesy of superstreet magazine, issue june 2006.
3.flush old coolant
