Tec2 Standalone?
Fuzz420
Are U Here 2 take My Baby
Can you help me find some info on this unit. I tried googling to find a main site but i couldnt find one. I know theres a newer version out the tec3, but i need info about the tec2.
I have an opportunity to trade my maftpro out and go full standalone:) I dont have any crazy hp goals,maybe 500hp w/ racegas everyblue moon, but thats about it. Also this will be for tuning on my na-t. I just want the best affordable tuning possible. If theres any reason why i should or should not trade my maftpro for a tec2 speak up(unless your trying to get my trade ;))
Any help is appreciated.
figgie
Twin Cities, Minnesot-ah
hmm guess beating Duane to this post :)
The tec2 works fine. Just be mindfull of the ECU prom that MIGHT dislodge (Duane was lucky, Melloyello was not). Also the tec2 just like the tec3 and tec3r require a 60-2 crank trigger wheel be fitted on the crank.
For ideas check out Duane (upgradedsupra) or Ultra7m (over in the car domain) for crank trigger ideas ;)
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
electromotive TEC is ok and can run anything but you need custom spak and ignition components so if you want to keep the stock stuff for 1jz/2jz it sucks.
like he said above you need to fabricate your 60 tooth sprocket to your crank pulley and tec2 is verry old late 90's early then tec 3 came out around 4-5 years ago.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
you can buy a tigger wheel and bolt it on
figgie
upgradedsupra said:
Tec was great but MoTeC FTW! :biglaugh:
Duane (I had to :D)
no no no
Motec + CDI8 + Mercury Marine Coils = NitroMethane Burning engine FTW. And no I am not kidding ;)
btw on that note... I know what you running ignition wise but what are you running coil wise? 2jz coils?
John Reed
117
Portland, OR
figgie said:
no no no
He is running 2JZ coils.
John Reed
117
Portland, OR
figgie said:
Hey John,
nice of you to be onboard here :)
btw Might give you a jingle on the RayChem DR-25 stuff ;) Had to put it on hold while some work was performed on the car :)
Good to be here! Seems like a pretty low key forum, I like that.
I usually stock quite a bit of the DR-25, and can get whatever you need. You can PM me here or just hit my email up if you need anything.
figgie
yes we are low key :)
and I will on the RayChem :) I think titan said the same thing you just said (about you are the man on the raychem DR-25 stuff ) ;)
NashMan
Aug 5, 2005
4,940
17
Victoria BC
talk about high jacked
they do ahve one it tad bigger then teh 7m balnercer all you need to do is drill 2 holes and bolt it on
figgie
or you can do what duane did and machine the 60-2 teeth right onto the crank ;) Makes for cleaner look :)
